big_jim_2
Aug 22, 2013Explorer II
When I installed my tire pressure monitors I had a lot of trouble with the extensions on my inside duals.. My best solution was to simply to remove them and put the monitors right on the valve stem. When I need to change the pressure I remove the monitors and screw the extensions back on for the change. I do have to lay on the ground and make sure the valve stems are in a position I can reach. Sound like like a lot of work but I usually only have to do this two or three times a year. P. S. I love these monitors as I can check my pressure on the toad along with the motor home. If I forget it warns me!
