wny_pat1
Aug 22, 2013Explorer II
bhildreth on 08/22/13 07 wrote:
It sounds like Dually Valves have many advocates. Any disadvantages to them? Can you put pressure monitors on them? How do we feel about pressure monitors?
I think a lot depends on your wheels. Dually valves are sized just like tires are sized. You can put a 9R22.5 on a 22.5" x 6.75" wheel, but you can't put it on a 22.5" x 8.75" rim. I think you might find the same thing with the Dually Valves. I have older stud piloted 22.5" x 6.75" which do not accept the newer style Alcoa valve stems, so this may apply to the Dually valves too. Best to call Dually Valve with the manufacturer and manufacturer part number of the wheel and ask them. Dually Valve has all kinds of wheel configurations depending on wheel age and wheel size.
Also when installing any TPMS, you want to make sure that they do not rub on your aluminum wheels. Believe it or not they will rub right through the aluminum polished finish of the wheel!
