willaldExplorer IIMay 06, 2013Dually valve extension issue, question..In order to allow me to easily keep (rear dually) tires inflated properly, I use the braided valve extension for the inner dualies, and 160 deg. U shaped solid extensions for outer duallies. This h...Show More
427435ExplorerMay 06, 2013I just have straight air fittings on my outside dual. I use a truckers tire gauge to check pressures. As for the inside duals, I use THESE. They won't leak the air out of the inside dual if the extensions come loose or break.
Related ContentDually valve stem extensionsExtension Hitch QuestionDually valve extensions?Are Dually Extension Brackets Unsafe?Dually questions
