May 06, 2013Explorer
willald wrote:427435 wrote:
I just have straight air fittings on my outside dual. I use a truckers tire gauge to check pressures.
That was/is what I would prefer as well, and what I tried to do when we first got the MH.
However, I've found that for whatever reason, due to the size, design of the wheels on mine...NONE of the trucker's tire gauges will work. Just can't get one with the right angle to get to those valve stems on the outer dual (and I've tried several!)
That, and even if you do get a gauge that will work, you still have to find an air chuck that will attach to it, when you need to add a little air.
Will
Well, I will admit that I took a ball-peen hammer to the wheel simulator and dented it down where the valve stem is. Without that, I couldn't get the pressure gauge to seat correctly.
