kitch251ExplorerJun 25, 2013Duck tape slide?Is it safe to travel with a slide (Bedroom) which is IN and not operative due to a broken motor? Should I duck tape this to get home (1000 miles)? Jim
mccsixExplorerJun 25, 2013I'm thinking a "broken" motor is a brake in itself. Have you tried to push the slide out?Or if you can you get to the bottom where the drive assy is,maybe you could clamp onto the actuating rod with a vice grip.
Related Contentduck tape for campersAdding power outlets in slide with no wiringEternabond TapePutty or butyl tape?flex tape
