tatest
Apr 09, 2015Explorer II
Valve for the inside wheel should be accessible through one of the holes in the outside dual wheel. It faces the space between the wheels, not the back side where the disc is. Many RVers use extensions or special longer valve stems, but the tires should be able to be serviced using dually pressure gauge and dually chuck if the hand holes are actually big enough for hands.
