coolcity
May 15, 2013Explorer
Blaster Man wrote:Bill S. wrote:
I never understood why some manufacturers have you put slides out before leveling. If the coach has a high or low corner, the body xould twist enough to cause the slide to bind, when extended. I have always leveled first, and then extend slides. My leveling system uses 4 hydraulic jacks. Maybe those with only 3, are different?
Same here, my manual says Brakes, Air dump, Level, Slides.
If it helps the acronym is BALS.
Like I posted already,and Tiffin agrees.Slides out first,dump air,then extend jacks+level.
38,774 PostsLatest Activity: Mar 01, 2019
