Butch50
Sep 30, 2014Explorer
Dakzuki wrote:
The holding tank drain configuration on the View/Navion depends on the model/year. Mine has two 3 inch valves and is all gravity (no pump) but your results may very.
On my 2015 24V the grey holding tank has the macerator pump to pump the grey to the front 3" drain valve. I could have installed a 3" drain on our grey in the rear if I had wanted to as the hole coming out of the grey tank is a 3" then reduced to a 1 1/2" line that runs to the macerator pump. Like I stated I just did mine a little different and decided to use the 1 1/2" to a hose. Then all I have to do is use my hose that I use to rinse my black tank to drain the grey.
38,766 PostsLatest Activity: Jan 10, 2026
