dougrainer
Jun 27, 2017Nomad
B.B.Upch wrote:
I tried to fix the blue plug on the cp board but still just getting the 2 zones that pop up. I have 2 units. zone 1 works the front A/C unit & then u press it & it goes to zone 3 (actually says zone 3) & both units come on....
so my question is... is there a way to get just the bedroom (rear) A/c unit to blow without the front & if not can I run both A/c units on a 30 amp 110 breaker if nothing else is going?
thanks
ON the Board are DIP switches. IF it states Zone 3 that means the Zone 3 DIP is ON. Turn it OFF and turn the Zone 2 DIP ON.
The SIMPLE answer is NO, you cannot run 2 AC units on 30 amp. Yes, you turn Zone 1 OFF and then run Zone 2(bedroom). You really need to replace BOTH upper AC boards and the wall tstat with the 5 button control system. You are just wasting your time trying to get it fixed. IF it was MY RV, That is what I would do. Doug
