rjstractor does have the facts straights on the fact that all ford 6.0L diesels are "detuned" in cab and chassis format.
But they can be "retuned" back up very easily. It is just a PCM adjustment.
Next. 6.0L are not as "problematic" as people like to make them out to be. I know, I have owned two, the first one had 180,000 miles on it, and the my now F350 has 100K. I have not had any of the issues people seem to complain about.
That being said, there is reasons for peoples complaints,
1. Lack of maintenance
2. Using tuners and increase engine pressures above the rating for the head bolts
3. Lack of maintenance on EGR system which causes coolant to boil and blow head gaskets.
4. Not changing oil at 10,000 miles or less intervals per the manual.
If you don't plan on building a tire burning drag truck, a person can make the 6.0L very reliable by buying and After market EGR cooler with tube pass through's instead of finned passages, or do an EGR cooler Delete.
Just doing this will get rid of the biggest frets people complain about. From guys I know who have lifted and modded 6.0L trucks, these are the guys that add tuners, exhaust and crank up the fuel flow to blow black smoke, then blow a head gasket, complain about the engine, but fail to inform everyone of the mods they did.
I just now did my EGR delete and when I pulled my Turbo, Intake and EGR cooler, there was no build up of soot of any kind, it was just a thin black grime.
I really have to wonder what those other people are doing to their trucks when I watch Youtube videos and they pull out an EGR valve caked in what looks like tar. Then the pull the EGR cooler and it is complete plugged. That really makes me think they are dumping too much fuel into the engine and causing more harm then good.
