- wallynmExplorerOP has DP not a gasser
jlrobison2 wrote:
On a gas model it is a indicator you have a brake or tale light not working.I'd Check it out first . - AvaExplorerQuite often in the past the cruise control used the horn fuse.
There are many parts to the cruise on motorhome. My older Fleetwood Bounder DP has Ford electronics as well as aftermarket vacuum pump and vehicle speed sensor. The repair can be timely to diagnose. Good luck Doug - jlrobison2ExplorerOn a gas model it is a indicator you have a brake or tale light not working.I'd Check it out first .
- Cloud_DancerExplorer III believe that the "350 Cummins" was part of the Spartan chassis option. But, my memory has never been very good.
I now recall that I've had good results from calling Spartan, with questions about electrical components (gauges and alternator problems come to mind). - wolfe10ExplorerWhat chassis?
