randallb
Mar 16, 2014Explorer
Ignition switch issues were not unknown on the Workhorse chassis. If I remember correctly there is more than one power out from the switch. It may also be the headlight switch itself. Most manufacturers split the primary lights and secondary lights at the switch. Since switches usually carry some heavy loads the power out of either the ignition or light switch may appear to be OK when checked with a volt meter. Volt meters place little or no load on a switch and this lack of load normally allows enough current to flow.
Randy
Randy
38,709 PostsLatest Activity: Mar 09, 2025
