Garry_Gayle
Nov 07, 2013Explorer
rgatijnet1 wrote:
If you get the RV Specific DynaBeads, you DO NOT need any special valve core. Other DynaBeads products, and some of the balancing powders, do require special valve cores which are put in as part of the installation process.
I run the RV spec Dynabeads in my 19.5 tires and I had issues with them getting into the valve cores when checking the pressure so I recommend getting the filtered valve cores.
