rgatijnet1
Nov 07, 2013Explorer III
wolfe10 wrote:
Would like to see in writing any tire manufacturer who recommends or even approves of beads, golf balls, etc inside the tire for balance.
I would like to see in writing any tire manufacturer that recommends Centramatic balancers.
Michelin does say this about internal balancing:
The use of internal balancing materials (such as powders, liquids, gels and/or beads) in
MICHELIN® Tires does not automatically nullify the warranty agreement covering the tires. If the material has been tested and certified by the component manufacturer as being safe for use in tires, the warranty agreement will remain in effect, provided that the tire is otherwise properly utilized and maintained. If, however, it is determined that the material adversely affected the inner liner and/or the performance of the tire, then the warranty agreement may be nullified.
timmac wrote:
I did some research and found Dynabeads are only reused if the tire guy does the job correct and not spill the beads on the floor.
I can't believe that deduction took research. So what happens to any type of tire balancing method if the tire guy DOES NOT do his job correctly? No product will offset a poor tire installer.
