timmac
Nov 07, 2013Explorer
rgatijnet1 wrote:timmac wrote:
I did some research and found Dynabeads are only reused if the tire guy does the job correct and not spill the beads on the floor.
I can't believe that deduction took research. So what happens to any type of tire balancing method if the tire guy DOES NOT do his job correctly? No product will offset a poor tire installer.
Was reading this on other forums about reusing Dynabeads, what happens you leave the RV at a tire shop and hope the service writer tells the installer to move the beads from old tires to new tires, I see a issue here with this being forgot or just not done right.
