farmingdad's avatar
farmingdad
Dynasty problems
Went to let slides out in front an would not come out an I kept holding button an it finally came out. And then went to start it and it started but gauges would not work nothing would there was a code come up on instrument panel said no data. Anyone had this problem before
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    With both my Accu-Slide (Cable car) and Power Gear (Rack and Pinion) slides it often takes multiple button presses to get it to work
    With the gauges had that happen ONCE.. Issue was the engine started before the computer finished POSTing (Power On Self Test) Solution was to shut down and restart. this time pausing for a sec at the ON before moving to START.
  • One thing is you should probably always have the engine running when you are extending the slides or leveling. I don't know your specific unit but we were told to always have the engine on when extending or retracting slides as well as leveling.
  • I'm not sure if the slide power comes from the chassis or house batteries (engine has to be off for slides to move). If the Dynasty is similar to the one we had, it has 3 hydraulic slides and one electric on the bedroom. The battery connections should be checked to make sure they are clean and tight.
    The hydraulic reservoir is probably located under the entry steps, I would make sure that it's full.
    The 'brain controller' for the slides (on ours) was under a panel in the second storage bay ceiling. I had to remove a panel to find it. I did have an experience of the slides not moving and a fuse/relay was loose. Sometimes holding the button like the guy did made it work. Check the 'brain controller' in the bay to make sure everything is tight.
    I ALWAYS plugged into shore power before moving the slides.
    Does it have air leveling? Hydraulic or both? If it has hydraulic leveling, that reservoir is in the front generator compartment on the passenger side. I had a shop build a brace for it as it broke from vibration.
    For the dash, I would also check all the fuses in the driver's bay outside under the driver's seat.
    Good luck and keep us updated.
    MM.
  • I am in buying it and this just happen I suppose take possesion this Friday and when talking with him today he told me that happened , it has got new battery's on it , it started right up
  • Farmingdad, 5 days ago you were going to look at a 'Dynasty'. So, you must have bought it, right?
    How was it working when you tested everything?
    With the very limited information that you are giving, I would lean towards the batteries.
    Hope it all works out.
    MM.
