Kit Carson wrote:
My 2008 Winnebago came from the factory with a spare carrier mounted underneath. The spare has never been on the ground!
The same as Desert captain.
A rectangular boxes made from 1" square tubing, and a centre plate with studs to hold the rim/tire. It's hinged on the drivers side mount to the frame. On the other side, the threaded stud coming down. Held up by a large wing nut and secured by a snap pin, so it can't vibrate loose.
Hint once a year or two, take it down and lubricate or use anti-seize on all moving parts/nuts. Better than having to use heat and a breaker bar when you really need it, side of Interstate in the rain.
Ken
