nbking wrote:
In my research for a new motor home, I looked for comments on the E350 Chassis. I found some disturbing comments concerning the stability and handling of the Chassis.
I contacted Pleasureway and was advised that the Excel was built on the E350 Van Chassis and indeed did have some handling issues. It was corrected by adding spacers and with other modifications. I previously owned an Excel and that appears to be true. The only problem I had with it was scuffing on the front tires. I replaced the tires but never did find out what caused it in the first place.
Pleasureway also said the Pursuit was built on the E350 Chassis and did not have any handling issues. However, from what I read, some Class C motor homes on that chassis did experience problems.
I would like to know if anyone has first hand knowledge of the handling performance of the E350 Chassis and, if the problems were restricted to earlier years. Information from late model year owners would be very helpful.
These E350's were imported into Australia,, they were a disaster, although very cheap.
Yes handling was diabolical. As a result nobody used them as a Motorhome base
