Harvey51
Sep 04, 2019Explorer
E350 gas cap
The original gas cap on our Ford E350 gradually failed to seal. For a few years a bit of grease on the seal kept the Check Engine light out but finally it made the check engine light always on and use...
opnspaces wrote:
I don't like replacing fuel caps or radiator caps. It seems like the replacement are never quite right. I'm curious, did you try a Ford dealer for the replacement?
I know you already replaced your cap, but for others who might be in the same boat. Anytime I have to deal with a non tethered cap I place the cap on the fuel pump at the station. At least that way if I forget it there is a chance it's still there when I come back. Or at the very least it won't have fallen off and been run over in traffic. :)
