garyhaupt
Aug 16, 2016Explorer
It'll be an exhaust manifold leak. The question is always..shall I fix it or not. And...it depends. It will allow more heat to escape from around the doghouse. The box, under which sits the motor..and that will be felt on the feet. However..there are two exhaust manifolds and they'll both have broken studs, and always the rear ones..the ones that are just a dirty nasty horrible job to replace. The Ford book says it's a heads off job...25 hrs per side. A good shop will get the job done from underneath but it is still a bunch of money. Like maybe $2,500 to 3 grand for both.
I can give you the name of a guy in Vanderhoof that can do the job. He did one side of mine and ran out of time to do the other. I had the other done here in Penticton a month ago.
Whoever you have do the job...they need to know what they are doing. Not get part way into it and shrug..and tell you they can't finish the job. It really is a mean, big job. And filthy. It has someone welding nuts onto studs and backing them out..maybe.
Someone in Alaska should be able to get it done..but ask around. Ask a NAPA store who they might recommend. Or..just leave it and drive it the way it is. It won't quit on you.
Gary Haupt
Gary Haupt
