F1bNormExplorerSep 11, 2019E350 trickle chargeThe 2006 Ford E350 has live (key removed) cigarette lighter (2) sockets in the dash. Shouldn’t I be able to trickle charge the chassis battery through that outlet? Thanks!
77rollalongExplorerSep 13, 2019check the owner manual, some you can change the position of the fuse so the lighter is powered all the time
Related ContentSolar trickle chargeTrickle Charging Chassis batterySolar Trickle charge working?Trickle charging my MotorhomeTrickle charging batteries
