gkainz
Jan 09, 2014Explorer
I remove my stuck wheels with the loose lugnut trick, but just leave the truck on the jackstands, spin the wheels with the engine (doesn't have to be very fast, maybe 5-10 mph) and then tap the brakes. The momentum of the wheel/tire will shift enough to break the rust/corrosion bond between wheel and hub. Also works to break loose the drums that my Dodge wears on the rear.
