fourthclassC
Nov 28, 2017Explorer
Front brake job pointers at Cloud Drivers request. First, thanks for the info on the rears. I did my front pads and calipers when one froze and I had to leave the camper overnight and come back the next day to fix it. I got rebuilt calipers (I always do because I have had to many freeze after putting in new pads) Also changed the rubber flex lines (new crush washers) Changing the calipers and pads was not a big job. I also repacked the wheel bearings and put in new grease seals. I used a long brass drift to punch out the seals once the rotors were removed. No big deal to do. I used high temp red wheel bearing grease (the really stringy stuff). Hand packed the bearings,installed and adjusted the stub axle nut. This jog is just like standard old rear wheel drive cars just with heavier calipers and rotors. PM me with any questions.
Again CD Thanks for all your input.
