Not_a_Yurt_'s avatar
Not_a_Yurt_
Easy fix of my screeching furnace motor - Bad connections!
A summary for you who don't want to read the gory details -- Clean up your electrical connections. Low voltage due to bad connections can lead to problems that are easily avoided by maintaining good electrical connections.
For those of you who want the long story, here goes:
I bought a used 1999 Winnebago from a private seller at a great price. All was well. Until last week, far from home, the furnace's squirrel cage fan motor started making a horrible screeching sound. Maybe the bearings needed lubrication? Opening up the panel, I saw that the motor has sealed bearings. But, optimist that I am, I sprayed lithium-based motorcycle chain grease on whatever looked like it might penetrate to the bearings. No difference.
I called the friendly on-site RV repairman who showed up on time. and was knowledgeable to boot. He told me that this problem can occur when the motor's bearings are shot (not likely, in his opinion), have some grit in them (again, not likely) or when the motor receives a low voltage current for some reason.
I told him that we were hooked up to shore power when this started, so, the low voltage hypothesis was unlikely.
He just rubbed his chin and then set about checking the wiring connections--jiggling here, unplugging and re-plugging there.
Well, bad connections, developed over the years since 1999, in a coach that sat for far too long without use by the previous owner caused the problem. Who would have thought wires that worked for weeks would start having problems?
With the electrical connections cleaned up, the furnace works just like advertised, and all is well. DW is happy, and I cheerfully paid the service charge without having to spring for parts and labor. (And friendly RV repairman even gave me a break on the service charge.)
So, my free advice is that I recommend you check and clean up electrical connections before you call the friendly on-site RV repairman to come look at your rig. Especially those connections under or outside the living area of the coach. I now know that low voltage caused by bad connections on the 12 volt systems just may be a problem you can fix yourself. And friendly RV repairman can then stay home.
My 2 cents, based on experience.
  • So, how many of us lube the bearings in our furnace motors BEFORE they fail? Maybe its time....
  • I seem to always find myself with older RV's. I think I just enjoy working on them. With that said, I'm guessing that about 80-90% of the problems that I fixed was caused by corrosion from sitting too long without use.
    Amazing what a little sandpaper and the right type of lubricant can fix on an RV.
  • My screeching fan motor required replacement. We were staying in the MH while on a trip so the repair location allowed us to remain in the MH while the repairs were completed. When the motor was pulled you could easily see the worn out bushing had even started to wear into the frame. Always ask for your parts during any repair. It is your right to receive the replaced parts.
    rocmoc n AZ/Mexico
  • Sorry, but LOOSE/corroded electrical connections will not cause a Motor to screech or make noise. The odds are the lithium you sprayed finally penetrated the shaft to the bushings and while the RV tech was there finally stopped the noise. Doug
  • Welcome to the forum! And thanks for the great write-up about the furnace motor, something that I will keep in my memory banks in case of future problems.
  • Actually, the fan motor has BUSHINGS, not bearings. And a couple of drops of light, non-detergent oil such as sewing machine oil can keep them going.
  • Kudo's to the honest repairman. You were a sitting duck for motor replacement.
  • never thought of that one. I always thought if the motor is squealing it is time to replace it. guess installing the new one cleans the connections while doing so.Go figure.
