SDcampowneroperator wrote:
Yes and no. Your converter through your Batteries from the 120v ac shore power provide 12v dc power to your lights, water pump, furnace, fridge, etc. - basic essentials.
120v ac shore power is required to power outlets, a/c, microwave etc. and to recharge the batteries via the converter unless you use a generator to power the system.
Batteries out should t make a difference as long as the converter is powered by 120 ac, doing its job to dc., feeding the dc system. ATC Fuses on the converter could be suspect.
