Racklefratz
Feb 27, 2021Explorer II
dcmac214 wrote:
NO! Not WD-40! 1st it's not a lubricant. More important, it'll dry and turn sticky in the process, collecting dust, dirt and whatever, leaving you with a mess to clean off. My go-to is dry silicone spray.
You're right about WD-40, which is always among the recommendations each time this subject comes up. The "WD" in WD-40 stands for "water displacement"; it was never intended as a lubricant, although it's widely MIS-used for that.
Not to hi-jack the OP's thread, but our coach has HWH hydraulic jacks installed from the factory, and HWH's position on lubricating their jacks is "DON'T". Just keep 'em clean. Any build-up of any kind of lubricant on the moving parts of the jacks is a dirt-magnet, and the grit on the jacks can destroy the seals over time. HWH says if jacks need repeated lubrication to get them to retract, there's likely to be a problem somewhere - weak retraction springs, etc.
38,783 PostsLatest Activity: Sep 24, 2026
