midnightsadie's avatar
midnightsadie
Explorer II
May 23, 2013
electric power in canada 120v ac or different
this will be hard to beleave , but my frig is wired for 230 v according to the mod number. dometic mod 7651L its always been a problem now we know why. amish cooling company found that the mod number being strange. so I researched the unit. in canada is there electric set up the same as ours?? this MH came new from canada. someplace along the line a big mistake has been made.
  • according to the Dometic spec sheet, your fridge draws a maximum of 190W at 230V
    A 500W 110/230 step up transformer is an inexpensive (<$50) alternative to replacing the fridge:
    http://www.newmarket-transformers.co.uk/step-up-transformers.asp
    http://www.amazon.com/Goldsource%C2%AE-Voltage-Converter-Transformer-ST500/dp/B0022QOSDK/ref=pd_cp_e_1
    http://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=step+up+transformer+500w
    http://salestores.com/powerbri.html
    http://www.frys.com/product/3696575
    good luck!
  • midnightsadie wrote:
    yep very poor cooling on ac. I just asked dometic to verify that it is a 230v frig.
    There is no question but that the model number you have cited is designed for 230V (which you have already figured out): Dometic RM 7651 L
  • the refrigerator wiring and the heating unit should be changed. so that the refer will work properly in north america..
  • yep very poor cooling on ac. I just asked dometic to verify that it is a 230v frig.
  • Canadian power is the same as ours; otherwise it would be a real nuisance sharing power on the continent. Since the fridge uses 12V for all its controls the only thing that should be affected is the heater when you are using AC. I would guess that the cooling capability on AC might be poor. Is this the case?
