GrumpyandGrandm
Aug 08, 2014Explorer
Did you tap on the magnetic switch? There may also be an inline fuse under the MH near the steps to check. You could also unbolt the arm from the motor and let the steps down and then tie them up with a bungee when you go to move.
38,766 PostsLatest Activity: Jan 10, 2026
