Islandman
Aug 08, 2014Explorer II
Get on Google or some search engine and enter Kwikee, I had problems last winter and got excellent info on troubleshooting the step. Mine would only come out 1/3 of the way, turns out spraying all the pivot points with WD40 solved the problem, took a few days for the WD40 to soak loose the binding spots. Let's hope it's something simple; but the troubleshooting message I got off the computer had all the different things to check and look for. Good Luck
38,766 PostsLatest Activity: Jan 10, 2026
