klutchdust
Aug 08, 2014Explorer II
synergy_58 wrote:hl remington wrote:
I used a needle nose pliers and removed the cotter pin that held the arm
to the motor and that will free the steps
Hm? I have looked for that cotter pin and don't see it anywhere. Where is it?
If you can see the motor then you should be able to see the arm and the pin at the end. There may be a pin with a cotter pin
holding it together.
38,766 PostsLatest Activity: Jan 10, 2026
