youracman
Jul 29, 2019Explorer
BeaverCamper wrote:
We recently went from a Class A to our current Class C.
2019 Coachmen Leprechaun on a Ford E450 frame.
It did not come from the factory with electric steps which we really liked in the Class A.
I looked on line and could only find replacement electric steps so I wanted to know if anyone has installed electric steps on their Class C that did not come from the factory with them?
If so who sells them?
Thanks!
I note your style coach has a body "drop down" in the area where the electric steps are on a lot of other Class C's. Evidently this is to make that first step up into the coach low enough so the owners can navigate it? You are wise to ensure this is "doable" and to request contact with someone who has done it, IMHO. If the normal "Kwikee" steps (like mine) have to be shimmed down to clear that "body drop down" ..... lack of sufficient ground clearance in the stored position might "quash the deal". Hope not.
Mine is a single-tread Kwikee (Series 28) and the stored height measurement is just under 6 inches. I do see a Series 31 in my PDF that has a stored height of just 4-1/4 inches....probably your best bet. If you get that far along, I'll try to email you a copy of that PDF (forget how I came by it.)
Good luck with the "hoped for" mod ...... and safe travels.
38,778 PostsLatest Activity: Jun 10, 2026
