Fixed(?) the water pump problem. Because "I don't have a clue what I'm doing, but I'm having a good time doing it"! I would bet that you knew that the pump is on a 3-way switch, one at the door and another in the bath. I didn't know that till about 2 seconds ago. Jeez!
As for the gas detector, getting to that fuse box under the hood is dang near impossible! There's a solid metal cooling conduit laying almost right on top of it.
I spent the afternoon turning ac circuit breakers on/off and pulling the coach fuses to see what they affected.
Here are my notes on that:
Tracing breakers Left to right 1 - 3
#1 green 30a main breaker(?), found no ac anywhere.
#2 red 20a both sides living area and TV outlet
#3 red 20a toaster oven and sink
#4 blue 15a bath and bedroom cabinet TV
(#4 also causes buzzing from power center)
(Could be battery charger)
#5 blue 15a microwave
Air Conditioner?
Tracing fuses. Left to right 1 - 9
#1 15a living area lights
#2 15a hall light and both kitchen and bath vent fans
#3 15a stove light/fan and bed lights
#4 15a ??? not water pump.
#5 5a ??? not water pump.
#6 5a ??? not water pump
#7 15a ??? not water pump
#8 15a water pump
#9 20a ???
Missed checking porch light.
So what are 4,5,6,7 & 9?
Need to check furnace and water heater sources.
