dougrainer
Jan 01, 2014Nomad
You have a 08 Tiffin Bus.
1. The battery tender is for the chassis battery ONLY. It works as your chassis batteries were up and started the engine
2. Your 08 Bus has a Inverter/Charger which will keep the Coach batteries charged. Since your chassis battery tender was working, your bus had 120 power in storage. The Inverter/Charger is automatic, so either the coach batteries are BAD( probable since they are 6 years old if original) and boiled dry. Check the coach battery water. BUT, even if they are DEAD, the Inverter/Charger should have supplied 12 volt power. There is an exception to this. IF the batteries went dry or could not charge, then some model Inverter/Chargers will shut down and not charge until you put a good battery or surface charge to reset the Inverter/Charger. Also, on your Tiffin, there is a 250/300 amp fuse between the battery and the Inverter/Charger that may be blown. If the coach battery water is low or gone, REPLACE the batteries. Doug
38,769 PostsLatest Activity: Apr 24, 2002
