dougrainer
Jan 02, 2014Nomad
KampingKris wrote:
hmm, havent read anything about auto gennie start.. will have to research that...Crankyoleman - does yours do that? But if we have the 12volt disconnected, would assume the gennie couldn't start? But we've only disconnected it at the door, so it might still have power
We had the rig only since Sept. and the dealer went through everything with us. Will check water level on batteries again though. Don't know how new batteries are.. but the chasse ones look new. Sent DH to storage. He says the batteries are sealed so no checking water apparently. And he says they are in somesort of sealed box. As you can tell, we are a bit mechanically challenged...
The chassis are sealed. The coach batteries from Tiffin are NOT sealed. IF they are sealed, then they have been replaced by the previous owner. Regardless, the Coach batteries need fully charged and load tested. Doug
38,769 PostsLatest Activity: Apr 04, 2026
