Stutch's avatar
Stutch
Electrical Issue 30 vs 50 Amps
Hey All!!! I have a Newmar 4018 with 50 AMP service. Just got back from a weekend where the pole was 30AMP only. I have one of those (2) 30 AMP male to (1) 50 AMP female splitter.
The coach would not charge batteries. I turned off everything except the fridge and it still did not charge the batteries. The power monitor recognized 119 volts coming in (on line 1), but it seemed there was not enough to charge the batts.
So, the inverter was using the batteries and eventually I go a LOW BATTERY fault.
I came home, plugged it into my 50 AMP outlet and all is perfect. What do you think? Is it the splitter, pole was not really 30 amps, what???
Thanks
  • Dump the adapter you're using and use a standard 30Amp male to 50AMP female adapter. It sounds like your 2,30AMP male ends are miswired.
  • Your Y splitter, the second leg was not connected to 120 power. So, only 1/2 of your RV had 120 power. Obviously the Inverter/charger side did not have incoming 120 power to activate the charger section. Doug
