Bubba_Bill's avatar
Bubba_Bill
Electrical problem..Magnatec converter?
Perplexing problem, Damon Intruder now in storage shed. Plugged in shed outlet, ran small electric heater for 4 to 5 days, no problem. Turned heater off, no 110 or 12 volt devices running. Went back several days later, all batteries drained to about 9v. Engine, gen would not turn over, 12v lighting very dim. 110v outlet GFI breaker thrown. Every time I try to reset outside GFI, trips. If I turn all inside breakers off, except main, breaker stays on. 'Receptacle' breaker seems to throw shorepower breaker every time, suggesting short. However, I've had this problem before. My question is: If batteries run down below a certain voltage, is there such a draw on the converter/charger that it would exceed 20 or 30 amps? Since I rent the storage barn, I don't know what the GFI outlet is rated at. I can plug my battery charger in to charge batteries without tripping the GFI. Not sure what my problem is! We wintered for 3 months down South with no problems. BIll
  • Try turning on all breakers except for the one handling the converter - that should determine whether the converter is part of the problem.
