I do this not for you but for others who may be reading:
mkguitar wrote:
a duff battery is a huge load on the system.
removing a battery protects the vehicle should there be a fault.
and removing the battery allows the connections to be cleaned and renewed on install
In the VAST majority of cases when a battery wears out, the internal resistance goes UP not down; thus it won't charge properly and actually presents LESS of a load not more.
If the vehicle is OFF at the time, it is isolated from the battery for the most part and can be completely isolated by disconnecting ONE cable; no need for physical removal.
Cleaning and tightening the cables also can be done without removal. Batteries are heavy and somewhat dangerous to handle; people are clumsy.
Your "one in a million" story about a battery catching fire is the exception and not the rule. I would ask you for the details but I'm a bit skeptical that it ever happened.....since NONE of the components of a common battery are likely to burst into flame even if you try.
