wolfe10 wrote:
Good grief!
No different than in your brick and stick house: Yes, two hots. If you measure from hot to hot you WILL see 240 VAC!
But just as in your house for all but a few large appliances, everything in your coach uses ONLY ONE HOT. So, one hot, one neutral and one ground= 120 VAC. Same as every outlet in your house.
Some things run on one hot leg (L1), some on the other hot leg (L2), just as in your house.
Thanks Brett! If there is ANYONE on this forum that should be believed, it is Brett Wolfe.
