rgatijnet1 wrote:
In my house, the neutral and ground are tied/bonded together in the main electrical panel. In the RV, the neutral and ground are not tied together in the main panel.
That is because (by National Electrical Code), the breaker panel in your house is a "main" panel, while the panel in your RV is classed as a "sub-panel". There are very different requirements for handling the ground and the neutral in a sub-panel. The "bond" to which you referred is in the main panel in the campground. You are a sub-panel to that main panel.
