larry cad wrote:
wa8yxm wrote:
rgatijnet1 wrote:
In my house, the neutral and ground are tied/bonded together in the main electrical panel. In the RV, the neutral and ground are not tied together in the main panel.
This is not true.. When you plug into the park pedistal, they are bonded, your RV is considered a "Sub Panel" I know exactly where mine is bonded 7 sites west of me (where the main panel is).
However it is true that when you are not plugged into a properly wired outlet,, Yes, then they are not bonded. This often includes both Generator and inverter power.. They may or may not (usually not) be bonded. My inverter is bonded if inverting. Not if Generator is in use.
But the RV is a "Sub" panel off the park main, and it's the park main where the bonding happens.
You should re-read what the this person said.
Thank you for pointing this out, Yes I did mis-read his original post, Apologies (I thought he said "not Bonded" and "RV" not House and Bonded) He was quite correct.
Again thanks for catching it.
