enblethen
Nov 25, 2014Nomad
Have you located your 12 volt DC power distribution panel. Normally next to the 120 volt AC breakers behind a small metal plate.
It is possible that the converter is in the same area. It is also possible that the converter may have reverse polarity fuses near where the 12 volt wiring terminates. it is also possible that the main fuse from the converter in the 12 volt distribution panel is bad.
38,782 PostsLatest Activity: Sep 19, 2026
