luvztheoutdoorz1 wrote:
A fuse on my generator will trip if I try to start it while connected to shore power.
You have something wrong with the wiring of your RV, possibly something pretty dangerous. Check to see if you have 120V at the shore power plug when the generator is running (with a meter, not with your finger!). If you do, get your transfer switch replaced immediately.
If it's a 12V fuse at the generator, it may be caused by the higher voltage from the converter as opposed to the battery. Check that the converter output voltage is in spec. If it is, there's something wrong in the generator as the 12V fuse should not blow under those circumstances.
