CA_Traveler
Jun 23, 2018Explorer III
The ground bus is bonded to the panel case. And somewhere the ground is bonded to the rig frame.
When all repairs are completed I recommend that you plug into a GFCI and check that none of the electrical equipment trips the GFCI. This establishes that you don't have a ground fault - ie amps leaking to ground.
38,766 PostsLatest Activity: Jan 10, 2026
