ScottG
Nov 09, 2019Nomad
Rick Jay wrote:
Ditto what ScottG said. I'm an EE as well.
What frustrates me to no end is when relatively simple circuit boards are potted (filled/covered) with epoxy so they can't be worked on. But if your board has everything accessible, then that makes it much more likely to be repairable.
After solder joints, the next common culprit is either bad connectors (or broken wires at the connector) or relays which no longer work.
~Rick
And we shouldnt forget those pesky solder balls!
Of course they usually show up pretty quick.
Scott
