wildcat72
Apr 13, 2016Explorer
Emergency Brake Problem
I have a 2001 winnabego Itasca Sunrise, my problem is when I set the emergency brake and when in park, on a downhill slope it moves forward, what could be the problem?
enblethen wrote:I could not determine that from his post or profile. If that is the case there is an adjustment at the end of the transmission at the top of the drum which houses two brake shoes. There is a star nut inside and with a large screw driver or brake adjusting tool the brakes shoes can be adjusted. It is adjusted like drum brakes on the car.
OP has a 2001 Workhorse
