rmalik1
Feb 27, 2015Explorer
Teacher's Pet wrote:
Does it click when you turn it on at the thermostat? If not, might be a bad ignition board, bad thermostat or stuck sail switch. Had our rear furnace go out 3 months ago. The thermostat selector switch was kind of hit or miss, and it fell apart when I opened the case to check for a fuse, so changed it. Then after that didn't fix it, I changed the board. No problems since.
seems like there is nothing I can do At this time
