tobydad
Aug 06, 2018Explorer
First thing is to remove the battery wires and clean the terminals on the battery and inside the wires. Start the engine with the emergency battery switch and then check the voltage while the engine is running. If voltage is lower than 13 volts then alternator maybe the problem or the ground wire to the battery may have come loose.
38,773 PostsLatest Activity: Apr 23, 2026
