77rollalong
Aug 06, 2018Explorer
check the battery voltage with the engine running, headlights on, and should be 13.5 to 14.8 normally if the alternator is ok. Normal meter voltage of battery should be 12.6 min, but only way to really check a battery is to have it fully charged, then do a load test. As others have said check the battery terminals make sure they are clean and in good shape.
38,773 PostsLatest Activity: Apr 25, 2026
