Harvey51
Aug 10, 2018Explorer
Why did it get severely discharged? If you don’t find out, the problem will happen again.
One possibility not mentioned is too many starts and not enough running time. Check the voltage before starting - should be close to 12.6.
Check the voltage with engine running to see the charging effectiveness - should be over 14, especially right after a start. I carry a voltmeter on a cigarette lighter plug to monitor these voltages.
38,773 PostsLatest Activity: Apr 24, 2026
