time2roll
Aug 10, 2018Nomad
mightykandy wrote:OK now you should verify the charging systems are working.
Got it to a battery store and it was diagnosed as dead battery. Changed it. Thank you all for the feedback.
Alternator should put 13.4 to 14.4+ volts on the battery terminals when running.
When stopped but plugged in you want the house charging system to maintain the battery. Plug in and check voltage is 13.2+ volts to indicate charging.
If you are not getting the voltage you expect please post the reading and we can help set it right.
38,773 PostsLatest Activity: Apr 24, 2026
